tranny swap wiring
Old 03-14-2008, 08:57 PM   #1
SOHC on this!!
GlassHeadlights's Avatar
Rep Power: 65 GlassHeadlights has a brilliant future
Default tranny swap wiring
i have a 90 civic si, it used to be a automatic i swaped it over to manual, all mechanical stuff worked except how am i going to wire up the reverse wires. there are two wires coming out of the tranny and one wire from the automatic engine wiring harness. i believe the reverse signal was from the shifter in the interior, i could be wrong.
GlassHeadlights is offline   Reply With Quote
Old 03-14-2008, 10:39 PM   #2
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Identify the sensor first. Manual transaxles usually have two. Reverse lamp switch (for reverse lights), and the VSS (vehicle speed sensor). The two-wire is your VSS. Your reverse lamp switch is on a ground controlled circuit and should only have one wire, but I may be wrong because I have seen some cars with a two-wire that were power controlled circuits, not ground controlled circuits.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 03-15-2008, 12:12 AM   #3
SOHC on this!!
i'm confused, so the two wires coming out of my standard tranny are vehicle speed sensor wires? so why aren't there two "vss" wires on my engine harness? on the automatic tranny the one wire that went to the auto tranny went to a solonoid looking thing.
Old 03-15-2008, 04:57 PM   #4
Rep Power: 14 91_civic_si has a spectacular aura about91_civic_si has a spectacular aura about
No, the two wires coming out of you tranny (green one and yellow one I think) are for your reverse lights. Your vss should be cable driven.
91_civic_si is offline   Reply With Quote
Old 03-15-2008, 05:00 PM   #5
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
I need to see it. Take a clear picture of it and post it.
Old 03-15-2008, 05:00 PM   #6
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Also post up the year/make/model car the transmission came out of.
Old 03-16-2008, 12:44 AM   #7
SOHC on this!!
i couldn't get a pic cause my camera was dead but the two wires coming out of the tranny are yellow and green. and the one wire on my engine wiring harness was a yellowish orangeish color. if that cable is the vss then i know what that is , my spedo works. tha tranny came out of a 1989 civic si and my car is a 1990 civic si
Old 03-16-2008, 12:46 AM   #8
SOHC on this!!
should i try to hook up the yellow wire out of the tranny to the yellowish wire in the engine harness then hook the green to a ground and see what i get or is that stupid?
Old 03-16-2008, 12:48 AM   #9
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
I'm confused. Were the two wires coming out of the trans. for the VSS or the reverse lamp switch?
Old 03-16-2008, 12:49 AM   #10
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Get a wiring diagram and find out exactly what it is.
Old 03-16-2008, 12:59 AM   #11
SOHC on this!!
the two wires out of the trans are reverse wires, the vss i believe is cable driven at the back of the tranny, i dont need to know about that.
Old 03-16-2008, 01:08 AM   #12
SOHC on this!!
this is what i found in my book. its saying the reverse wires are in the center consol in the interior.the wires coming off of my tranny (yelloy and green) must be reverse because under the center consol there isn't one wire.
Old 03-16-2008, 01:23 AM   #13
SOHC on this!!
i have a 88 civic dx standard donor car i could take wires off of if that helps i'll take a look at it in the light of day
Old 03-16-2008, 01:46 AM   #14
universal logic protocol
whiterabbit06's Avatar
Ride:  99 VW GTI 07 Jeep Compass
Rep Power: 81 whiterabbit06 has a reputation beyond repute
whiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond repute
Send a message via AIM to whiterabbit06 Send a message via MSN to whiterabbit06 Send a message via Yahoo to whiterabbit06
The wires comming off of the shifter plug are for the ECU. The Green and Yellow wires comming off of the transmission are for the reverse lights. The Green goes to the Positive on the Reverse Lights and the Yellow goes to the Fuse Box.
Originally Posted by TurboMirage View Post
i live my life one billable hour at a time. for that 60 minutes or less, im expensive.
90 Civic Hatch <= Sold
99 VW GTI <= BIG F'IN POS <= Finally got it fixed, it's running good now
07 Jeep Compass
If you ever find anything I write usefull please leave rep.
Rebuilding a Transmission
http://www.the-whiterabbit.com
whiterabbit06 is offline   Reply With Quote
Old 03-16-2008, 01:59 AM   #15
SOHC on this!!
thats what i needed to know, thx
Old 03-16-2008, 02:10 AM   #16
It's what I'm here for.
07 Jeep Compass
Old 03-16-2008, 11:57 PM   #17
SOHC on this!!
i got them working , but almost by myself! the wires at the shifter weren't just for the ecu. i folloyed all the wires coming from the shifter and two wires went to the back of the car and they happened to be the same color as the two wires on the tranny!. i ran a 18 gauge speaker wire from the tranny to the shifter in the interior and there happened to be a positive wire when the ignition was on in the plug for the automatic so i coupled the wires there and it worked out prefect!
Old 03-17-2008, 12:34 PM   #18
Might want to try something other than speaker wire. What age do they let you kids drive in Canada?
Old 03-19-2008, 12:43 AM   #19
SOHC on this!!
i'm 14 now and at 16 you get a "L" which is a learners and a adult has to be in the car at all times. then after a year you get a "N" which is a new driver i think and you get to drive on your own then after another year you get your full lisence. it sucks that you guys get to drive at 14i'm trying to make my 90 si as nice as possible before i start driving
Old 03-19-2008, 02:53 AM   #20
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 5 monotech909 is on a distinguished road
Be a safe and responsible driver thats all I have to say....... Peace!
monotech909 is offline   Reply With Quote
Old 03-20-2008, 04:58 PM   #21
I dont know where you can drive at 14. It is 16 as far as I know. South Carolina might still be 15 but I dont think so. Good luck with your build, you should have plenty of time to do it right the first time.
Old 03-23-2008, 12:04 AM   #22
SOHC on this!!
when i was in mexico there was a couple from alaska that said u could drive at 14 i dono then
Old 03-23-2008, 04:43 PM   #23
Yeah, a four wheeler or snowmachine, not a car.
88 crx dx B16a swap need some wiring help J's honda racing Civic and CRX - EF 13 03-26-2009 12:20 PM
How To -auto To Manual hondaburner95 Accord 34 09-14-2008 07:15 PM
88 crx dx B16a swap need some wiring help J's honda racing Civic and CRX - EF 0 02-09-2008 01:21 AM
Tranny Swap Broke_Tuner Prelude 4 12-05-2007 04:47 PM
does anyone else know about the b-series tranny swap to f22 block.... hondaburner95 Members' Lounge 1 02-04-2007 03:14 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
