tranny vibes/issues
Old 03-04-2007, 08:51 AM   #1
Ride:  92 GSR Hatch, 07 WRX
Rep Power: 10 juicedz has a spectacular aura aboutjuicedz has a spectacular aura about
Send a message via AIM to juicedz
Default tranny vibes/issues
Ok so i just got done the b18 swap in my 95 civic. Decided to take it out last night to dinner. First issue was the clutch. everything was bled and seamed fine on my test run around the block. Now the pedal is releasing as soon as I push it it about 3/4". Second is I have a slight vibration at low speeds in 1st and 2nd. Could the be because of the lsd trans. Ive never drove one only a jeep with a locker in the rear.
"Insert corney line here"
juicedz is offline   Reply With Quote
Old 03-04-2007, 08:01 PM   #2
Ancient Member
welfare's Avatar
Ride:  RHD EG6 jrsc b18c :)
Rep Power: 29 welfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the rough
Send a message via AIM to welfare
check the clutch adjustment at the pedal where it goes into the clutch master cylinder, it is a threaded rod with a locknut like a tie rod end, just adjust it to where it feels comforatble to you.
if the lsd tranny is new, or the lsd itself is new it may need to be broken in, make sure the fluid is topped off and of the correct type and then follow mfgr's break in procedure.
and a locker isn't reall an lsd, hence the name "locker" lsd doesn't actually lock like the locker does.
9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6
doing it myself!
6/1/09 RHD on the road, now time for Body Shop
7/10/09 jackson gsr into rhd+hondata
91 rex ls/vtec
b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER!
13.881@102 on street tires
Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some
reptation, then give 'em a point!---,
welfare is offline   Reply With Quote
Old 03-05-2007, 08:49 AM   #3
Ok i readjusted the the rod and it seams to be better. I still need to check the fluid. SOunds like the motor mount inserts are causing the vibrations. Once I get some more oney I will get a new set and hopefully be good. Thanks
SI tranny or whether? Atownz05 Civic and del Sol - EG and EK 13 03-16-2008 09:41 PM
s20 tranny type of oil BORICUAFLAVA2 General Tech and Maintenance 4 06-29-2006 06:18 AM
WTF my Tranny is bleeding!?! Citizen_Insane General Tech and Maintenance 5 05-04-2004 02:53 PM
tranny for my b16 5thgenerationc HYBRID -> EG-EK / DC 3 09-10-2003 05:28 PM
Zc Tranny Problems. hardweapon HYBRID -> EG-EK / DC 1 03-24-2003 11:07 AM
