Transmission seal issue [b16 cable]
Old 07-23-2007, 10:59 AM   #1
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
Default Transmission seal issue [b16 cable]
i have a b16 non lsd cable transmission and my rear seal is leaking. however i dont know which seal to buy at auto zone?
do i get the 90-93 integra cable seals or the 99-00 si hydro seals?
i need to buy all this stuff before i change the gator axles i'm buying off will.
http://pandora.com/
Old 07-24-2007, 08:21 AM   #2
formby's Avatar
bump
http://pandora.com/
Old 07-25-2007, 12:42 PM   #3
formby's Avatar
no one?
http://pandora.com/
Old 07-25-2007, 01:44 PM   #4
jlicrx's Avatar
if you have axle seals leaking, the passenger side ares all the same 90-00 Integra - the driver's side depends on which intermediate shaft you have - 90-93 intermediate shafts have female end where the axle goes in and use 90-93 Integra seal at the transmission - 94 and up intermediate shafts have a male end where the axle goes to and use the 94 and up Integra seal in the transmission
ZCspeed Racing
Old 07-25-2007, 02:43 PM   #5
formby's Avatar
thank you soooo much.
so it should not matter if ita a b16 or b18?
the cases are the same?
http://pandora.com/
Old 07-25-2007, 02:56 PM   #6
jlicrx's Avatar
yes, it won't matter
ZCspeed Racing
auto to manual conversion d112crzy HYBRID -> BA-BB /CA-CD 0 09-13-2006 11:27 AM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
B-series Transmission Guide pissedoffsol Swap Articles 1 06-01-2004 05:46 PM
B18c5 In 88 Crxdx Will There Be Room 4 Turbo?>? T4 88crxdx HYBRID -> EG-EK / DC 13 02-04-2003 05:03 PM
