uh oh, oil on my plugs and wires
Old 02-08-2006, 10:17 AM   #1
The G37....
get_nick's Avatar
Ride:  Black G37, '07 R6
get_nick has a reputation beyond reputeget_nick has a reputation beyond repute
get_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond repute
 FaceBook
situation:
i have a 1992 civic vx. 165,000 miles. stock motor. so my car bogs every once in a while. i will be driving and it will just stop accellerating. kinda like du du du vrooooom. it stutters then picks right up. it doesn't do it a lot, but maybe once every 4 or 5 minutes. it's really annoying.
what i tried to do:
so i tried replacing the fuel filter, plugs and all the tune up stuff. didn't work. and when i pulled the plugs out, there was oil on the plugs and wires of the two center plugs.
what is the deal?
I changed the page layout. let me know what you think. I need feedback.
www.obamacies.com
get_nick is offline   Reply With Quote
Old 02-08-2006, 01:23 PM   #2
driver1 is an unknown quantity at this point
the spark plug grommets are gone just buy a valve cover gasket SET and replace them and youll be set...and replace the valve cover gasket also cause u have to take it off to change them and u have to buy it to get them
driver1 is offline   Reply With Quote
Old 02-08-2006, 03:50 PM   #3
VTECin5th's Avatar
VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
$30 at autozone for the SET
VTECin5th is offline   Reply With Quote
Old 02-10-2006, 11:45 PM   #4
Lost in a sea of rednecks
GSRCIVICTN's Avatar
Ride:  5th Generation Honda Civics
GSRCIVICTN is an unknown quantity at this point
Make sure you replace the plug wires also. I was taught that the oil isn't exactly good for them.
GSRCIVICTN is offline   Reply With Quote
Old 02-11-2006, 01:10 AM   #5
Führer Mod
eg6sir's Avatar
Ride:  Le Car
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
it bogs down a little when you first take off... it sounds like your fuel pressure.. my car did that.. fuel pressure was way to high
eg6sir is offline   Reply With Quote
Old 03-06-2006, 09:32 AM   #6
Ride:  92 civic hb
flydex28 is off the scale
Wait...does it start vibrating and losing power as you get on the gas while driving? If it does it might be your catalylitic converter if you have one.
I had the stock 92 cx whith the front mounted cat and it got plugged really bad and would start doing that while driving.
flydex28 is offline   Reply With Quote
Old 03-06-2006, 09:53 AM   #7
The G37....
get_nick's Avatar
 FaceBook
<div class='quotetop'>QUOTE(flydex28 @ Mar 6 2006, 10:32 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I was thinking that to. I haven't had much of a chance to look at it. i have been spending too much time at work. but it just bogs for a second it's like, du du du vrooooom. then it takes off like normal.
www.obamacies.com
Old 03-09-2006, 04:05 AM   #8
5speed4life is off the scale
Send a message via AIM to 5speed4life
<div class='quotetop'>QUOTE(get_nick @ Mar 6 2006, 10:53 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
also a malfunctioning O2 sensor will do this.
Spooning Leads to Forking 99% Of the Time.
Sig edited by moderator - No pics please
5speed4life is offline   Reply With Quote
