| | LinkBack | Thread Tools |
| | #1 |
| Sleeves+boost=Love Join Date: Nov 2002 Location: Oak Harbor/Battle ground,wa Age: 24
iTrader: 0 / 0% Ride: 91 crx
Rep Power: 18 | Allrite i did a mini me swap (d16a6 block,d16z6 head) in my 90 civic hb. She drives awsome and i have no check engine lights coming on or anything. Thank god. BUT, the damn thing keeps over heating and i can NOT figure it out. I have put a new thermostat in thinking it was that, that didnt fix it, then i put a new water pump in, that didnt fix it. So i bled the coolant and tried to get all the air out, and it is still doing it. I NEED TO GET THIS PROBLEM SOLVED SO I DONT BLOW ANOTHER HEAD, lol Someone please help. Should i flush the radiator? Oh by the way it only over heats like when i am stopped at a light or something then start accelorating again to the speed limit then it will start over heating until i let off of the throttle and just cruise, but sometimes it stays realy hot. and YES the radiator fan does work. Thankx in advance, Dan
__________________ I rule. |
| | #4 |
| Senior Member | i did this same swap in my 90 si hatch. unfortunetly i blew the trans w/ in 20 mins from when i got the car back ! haha . i also noticed when i did this swap my car ran so hot practically overheating as you explain. May sound dumb but i had smoke coming out of my heater core.. i dont know if it was shot or what. i would do some more research on this swap. i did weeks and weeks of it and i never saw any problems w/ heat. |
| | #6 | |
| Senior Member | Quote:
| | #9 |
Rep Power: 18 | allrite i flushed the hole entire coolant system for 2 hours and it hasnt overheated yet, tommarrow i am going to go drive alot so we will see what happens!alot of shit came out of my radiator. thanks for the help guys! hondaswap members are the shiat! -dan |
| | #10 |
| Senior Member | is there steam coming out of rad. when u open cap(with rad full) check copression.. and hope u dont have blowen u know what............ if no u probably have a plug rad. to check use a temp info red light just check inlet temp and outlet temp |
| | #11 | |
| B happy Join Date: Nov 2002 Location: Location: Location: Location: Age: 38
iTrader: 1 / 100% Ride: dohc 95 egg
Rep Power: 187 | Quote:
