VALVE tools?
Old 10-04-2006, 05:27 AM   #1
gettocrx's Avatar
gettocrx is an unknown quantity at this point
Send a message via AIM to gettocrx
Default VALVE tools?
Hey guys! I was wondering where I could get the valve lash socket tool tp do a valve lash on the b series vtec head (socket with that handle and hole for the screw driver)? Its kind of in there to use a open end and a flat head! Also the valve spring compressor (universal overhead) I have looks like it wont fit in there.which one do ya recomend?? Thanks!
gettocrx is offline   Reply With Quote
Old 10-06-2006, 03:02 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
GearRatchet set and a screwdriver- then you can do all sizes of valves.
Old 10-06-2006, 08:40 PM   #3
GSRCRXsi's Avatar
GSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to behold
i made my own.
took a 10mm deep socket and a 9/16" box end wrench (the size doesnt matter too much, just make sure its just barely too small to fit around the 10mm socket)
then i heated the wrench up red hot with a propane torch and pounded the socket into the wrench with a sledge hammer.
then i let it cool (used some water to help it along cause im impatient lol) and the metal contracts around the socket making it grab even more so it doesnt slip. (i tried doing it with a larger wrench and no heat but it slipped and didnt hold onto the socket well)
done.
HEAT
'91 CRX si
'10 WRX
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 10-18-2006, 11:54 AM   #4
Trick or treat
REDMAC's Avatar
REDMAC is on a distinguished road
i
made my own.
Damn that's a good one.....
REDMAC is offline   Reply With Quote
Old 10-18-2006, 12:57 PM   #5
kaoskustoms is off the scale
Send a message via Yahoo to kaoskustoms
just buy one corwell i think they are about 50
then you can start charging your friends for valve adjustments and make your money back
kaoskustoms is offline   Reply With Quote
Old 10-18-2006, 08:54 PM   #6
gettocrx's Avatar
well, i found out it's called a jam nut wrench! its like $10... And it makes life much easier!
Old 10-21-2006, 01:34 PM   #7
Blah blah blah....
MikeBergy's Avatar
MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
Valve adjustment with a 10mm wrench and screwdriver FTW! It's a two handed job anyway, why spend money on fancy tools that only good for one thing, when normal tools do the job just fine?
MikeBergy is offline   Reply With Quote
Powdercoating Valve Covers and other parts mntdewred Parts: For Sale/Trade/Wanted 349 10-12-2008 03:31 PM
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 08:26 PM
How to build a "reliable" lsvtec/b20vtec bambam General Tech Articles 2 07-02-2006 04:48 AM
****Custom Valve covers Done Here!!!! CHEAP!!* flappy188 Parts: For Sale/Trade/Wanted 4 03-17-2006 07:12 PM
ABS (anti-lock Brakes) Troubleshooting Codes pissedoffsol Reference Materials 0 05-19-2005 11:59 AM
