Vtec dont want work
Old 04-05-2006, 02:10 PM   #1
Rep Power: 10 shifter is off the scale
we have swaped in '94 civic coupe b16a engine. Stock engine was d15b7. stock p06 ecu i've swaped to p28 ecu. wrote p30 bin with switched of: knock sensor, VTP, injector test, eld and etc. wired wire from A4 ecu pin to a vtec solenoid. if i power it directly from battery + - vtec work, but ecu dont want to engage vtec (i've wired a bulb inline to vtec solenoid to look if ecu trying engage vtec.) ecu chiped with a Crome. vtec set at 4k..... no CELs. i've used another 100% working P28 - same result. why it dont want work?
shifter is offline   Reply With Quote
Old 04-06-2006, 07:46 PM   #2
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
you need oil pressure to activate VTEC as well. Make sure your oil pressure sensor isn't off, or unplugged.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 04-07-2006, 09:45 AM   #3
<div class='quotetop'>QUOTE(TurboMirage @ Apr 6 2006, 06:46 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
nono. everything is hooked up. i am getting no cels. if i connect + from battery directly o vtec valve - it's works. i hooked 12v lamp inline on wire wich goes from ecu to vtec valve. it not light ether...
