i have a h22a motor in a 94 accord the problem is vtec does not engage. From 2000rpm till 5600rpm motor runs faster than 5600rpm and up i dont get it its like something is holding me back.checked oil is perfect.anyone could help ill greatly appreciate it.
#4 | |
i have p13 ecu the only code im throwing is for my 02 sensor i dont think that could be the problem with the vtec not engaging |
#5 |
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
hmmm, i am under the impression that any CEL will throw the ecu into limp home mode...
the ecu cannot tell if the motor is running lean or rich, so its not going to go into full blown performance mode unless it knows everything is checking out ok... CEL = no vtec... __________________
I'll blow a hole in your face then go inside and sleep like a baby. |
#6 |
WRX Sellout
Ride: 2002 WRB Impreza WRX
Not true. You can engage VTEC on certain codes. I'm not sure if an O2 sensor is one of them, though. I'm pretty sure it's not.
This space left intentionally blank. |
#8 |
WRX Sellout
I know for a fact a knock sensor code won't disable VTEC. An IAT code won't disable VTEC. Both just cause the ECU to retard timing to keep any problems from happening.
I'm pretty sure that an O2 sensor code won't disable VTEC, because I seem to remember my O2 sensor going out, and I ran like that for a few days before I replaced the sensor. Once again, it just causes you to lose some power from the ECU being careful. However, back to the original question: The ECU has to be throwing some other code if VTEC isn't working. Are you sure it isn't throwing multiple codes? __________________
#9 | |
#10 |
WRX Sellout
If anything having to do with VTEC was wired incorrectly, it would be throwing a code. Can you check to see if it's throwing multiple codes?
#11 | |
how do i do that bro? last time my friend did that for me.If you can explain it howq to do it i would do it right now |
#12 |
TTIWWOP
check the refrence section for honda ECU error codes...
it tells you what the codes are and how to retrieve them... __________________
#13 | |
thanx |
#14 | |
thanx [/b][/quote] i checked the reference but i couldnt find the brown and black wires behind the center console if anyone knows where they are exactly located just tell me it would help a lot oh yeah a have a 94 accord with a p13ecu and a h22a motor in it if thatll help |
#15 |
RETIRED
some accords and preludes are sometimes lcoated in the middle of the car, behind the radio on the passenger side left foot kick panel. try there. if you find the ecu, its right next to it hanging out.
#17 | |
is it like a blue plug if it is i only found the brown wire no black wire.i found the plug under the glove box.the glove box is infront of the passenger right or is it in the middle next to the driver i just got it mixed up. |
#18 |
WRX Sellout
It's definitely the plug that you found. You need to jumper it with a paper clip or something like that.
#19 | |
#20 | |
[/b][/quote] multiple codes are:13 15 21 23 36 i need some serious help |
#21 |
Ride: '92 Civic CX
The person who did your wiring sucks... Where are you located?
Garage: 1992 CX Hatch > Current Money Pit Grave: R.I.P. 1995 Integra GSR R.I.P. 1990 DX Hatch R.I.P. 1990 CRX Si |
#22 | |
im in tampa florida. |
#23 | ||
TTIWWOP
that sucks, did you look em up? Quote:
and did you pay this guy?? what exactly DID he wire cause it sure as shit wasn't any of the above... damn not sure on this but i think A6 and A11 need to be swapped on your ecu... __________________
#24 | |||
i dont even know what the hell he was thinking i think he used the ecu diaphrams from an h23 motor i found some papers that he left in the car and they were from an h23 2.fucking 3 liter motor i told his dumbass it was a h22a.i dont even wanna go back to his fucking shop man any of you guys know where i can get that fixed in florida,tampa |
#25 |
TTIWWOP
not sure whos from that area... i would post in the regional...
