i bought a 95 Gsr two weeks ago. i have installed a cold air intake, exaust, and a vtec light. The vtec light illuminates at about 4900 rpm at full throttle, where a very subtle sound difference occures, also a little bit harder pull. Then at 6000 rpm the vtec picks up again, with a reduculous sound difference, and a lot harder pull. My friend put a vtec light just like mine in his 2000 civic si. When his light illuminates it has the hard pull and more intense, abrubt sound difference at 5000 rpm, as mine has at 6000 rpm, but the civic never has a second powerban, the civic just holds the "new tone" until redline.
My Qustion: Should my vtec be at full force when it first kicks on? Is my vtec just not comeing on until 6000 rpm? Does the Gsr vtec work exactly like the Civic Si? Thanks for your help. |
#2 | |
Member of the 20 nut club
the slight sound difference you hear is the secondary intake runners opening up
МОΛΏΝ ΛΑΒΈ |
The light is coming on when vtec starts but it's not engage in either car till between 5600-5800rpm if stock ECU. (As far as I know but might be wrong)
<span style=\'color:red\'>'90 Crx 12.6 @109.29 <-Sold '01 Gsr 15.2 more show then go <-Sold</span> <span style=\'color:blue\'>Forced to go SLOW because my Xb has no GO!!!</span> |
#4 | |
hondas do not have "levels" of VTEC its either on or its off
МОΛΏΝ ΛΑΒΈ |
#5 |
Okay but doesn't vtec engage around 5600-5800 stock normally then?
#6 | |
its different on each type of VTEC engine ... not sure on the stock points
МОΛΏΝ ΛΑΒΈ |
#7 |
some do have levels only, a couple though
Get Xbox 360 Games and Accessories for free. |
#8 |
no they dont!
And Dont try to say i-vtec doea because it dosn't i-VTEC In addition to controlling lift and duration, like other VTEC systems, the "intelligent" i-VTEC™system uses Variable Timing Control (VTC) to adjust "camshaft phasing." By varying oil pressure, VTC can continuously vary intake timing relative to the engine's exhaust timing. The result of i-VTEC is improved response and enhanced performance at low engine speeds and efficiency across a broad power band. |
#9 |
it's called 3-stage vtec. its in an itr(i think) and some older economy motor
#11 |
Damn it i fucked up you're right it's the s2k
#12 |
.....deagle..... |
#13 |
If I am not mistaken, the three stage VTEC is a VTEC engine with a second VTEC that is activated when the vehicle gets to highway speed. instead of the change resulting in another powerband it switches to super economy mode.
1990 white crx dx immaculate shell... waiting 1995 black del sol VTEC,jdm B16A, black 15" rota slips, BFG g-force ta kdw's, kyb agx's, eibach pro-kit, tanabe strut bars, tanabe hyper medallion, dc header in 1962 honda launched their famous ad campaign: "you always meet the nicest people on hondas" ...chirp <span style=\"color:#3333FF\">WTB</span> gsr head , ls block, or b20 block. |
#14 |
could be i haven't read much about it i just know of it. but thinking of s2k's on the highway, i saw one with a flapping wing in tennessee a week or so ago and it flew past us and then about a half hour later we saw a cop fly by with his lights on and then like an hour later we saw the cop on the shoulder and the s2k in the trees. sucks for that guy
#15 | |
the gsr engine (if stock) hits vtec at about 4400 rpm, but the secondaries are still closed, and at about 5800 rpm the secondaries open up
91 CRX si 95 Integra LS I DO NOT answer tech questions via PM. Use the forums!!! Quote:
get a free flatscreen, yes it works! Please give what you can to the Tom Cote Medical Fund http://honda-tech.com/zerothread/1828476 |
#16 |
your correct ^ about the GSR with crossover in the 4's and the butterflies opening in the 5's.
Milan __________________
#17 |
does someone have a 'how stuff works' about this???... im a little lost
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (94RedSiGal @ Dec 2 2003 @ 12:27 AM)</td></tr><tr><td id=\'QUOTE\'>Having a ClubSi, Honda-Tech or HondaSwap sticker on them would just scream "Steal Me Now! I'm a special car!" to thieves.</td></tr></table><div class=\'signature\'> |
#18 |
Not sure if this helps but in the oem GSR the vtec crossover is at 4400rpm so that is when vtec engages. Now at 5800rpm there are secondary butterflies (kind of like small extra tb's) that open up within the GSR intake manifold, that is why the manifold looks unique.
| VTEC & Wireing | an203888 | ECU's, Electronics, and Tuning | 4 | 03-21-2008 07:48 PM |
| How to wire vtec | 92b16vx | General Tech Articles | 3 | 06-17-2005 06:13 PM |
| no power with vtec | 95sir | HYBRID -> EG-EK / DC | 65 | 11-08-2003 07:07 PM |
| What Turbo To Get? | SolReaver | Forced Induction | 107 | 05-07-2003 10:37 AM |
