i just installed my walbro fuel pump, which was an absolute disaster btw. anyway its in and its working but my fuel pressure jumped almost 8 psi at idle. it was at 42ish, now its at about 50. i have an aem fuel pressure regulator, just havent installed it yet. do i need to install it and get the fuel pressure back down or is 50 psi okay for a gsr motor? reason i'm asking is because i want to sell the fpr if i dont need it so i can buy other things for my turbo project.
angry bear
Ride: 02 Acura RSX
i would keep the regulator, install it and see what the reading is at, and if needed then adjust the pressure down
XBL: ripperbone Vouches / Good buyers or sellers = * pissedoffsol* socolsvtec* lshatchcx18* hybrid89* aafryf* integraracing91* twistedimage* NoJokE* 5speed4life* Estorvito* sheekdude* antonio* VTECPOWER* 98hybrid* traitorzxiong* preludebuddy* wanderinman* TurboMirage* kaoskustoms* B16RacerN2NR* HPHP80620* |
angry bear
Ride: 02 Acura RSX
im not sure about that, if its different than the b16 or not.
I have my b16 at 30 psi at idle and when you hit the throttle it spikes to 40. my set up is set for stock pressure. I would think that your setup should be the same. __________________
