warm up problem
Old 12-31-2003, 08:39 PM   #1
highperboi is off the scale
Send a message via AIM to highperboi
My friend has a 91 crx with a b16a and he just replaced his intake manifold and now it has a problem warming up. The intake manifold didnt have a spot for the FITV(fast idle thermal vavle) if that has to do anything with it. Also the coolent is bypassed the throttle body and intake manifold which means there is no coolent to close idle air controle valve. does anyone have any ideas on what is going on?
highperboi is offline   Reply With Quote
Old 12-31-2003, 09:52 PM   #2
I'll be back...
B16RacerN2NR's Avatar
Ride:  96 DB8, 06 Mazda 5
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
thermostat could be stuck open
B16RacerN2NR is offline   Reply With Quote
Old 12-31-2003, 09:55 PM   #3
its not a heating problem it heats up fine. it only does it when its warming up when he first starts it...
Old 12-31-2003, 09:59 PM   #4
I'll be back...
it only "does what?" when warming up???
Old 12-31-2003, 10:08 PM   #5
it will die if you dont give it some gas. after it warms up then its normal...
Old 01-01-2004, 03:16 AM   #6
noone has had this problem before?
Old 01-01-2004, 01:52 PM   #7
Accordturbo94 is off the scale
Thats your problem! Also the coolent is bypassed the throttle body and intake manifold which means there is no coolent to close idle air controle valve. does anyone have any ideas on what is going on?
You still need to at least have that part hooked up! the throttle body is mechanical! when its cold it knows to open the throttle plate more.. after it warms it closes! Its thinking right now its ok! give it a try
Accordturbo94 is offline   Reply With Quote
Electrical Problem With My 1986 CRX Si The_MATRIX General Tech and Maintenance 0 06-17-2004 05:08 PM
idle problem NotUrAverage_Si General Tech and Maintenance 0 03-25-2004 10:37 PM
Prelude 1997 Heat problem... ovcrash General Tech and Maintenance 2 03-12-2004 10:45 AM
Vetc problem Mr.Steve HYBRID -> ED-EF / DA 2 08-07-2003 10:51 PM
HELP! ZC problem bearlan General Tech and Maintenance 2 06-30-2003 02:23 AM
