| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | ok so just recently we got dumped on with tons of rain.....i drove through a little water that i thought wouldnt hurt my car...well my cold air intake sucked it up and its now in my oil.....it runs though and i have been and will keep changing the oil frequently to hopefully fix my problem....if anyone has any advice please tell me bc i need the help.....thanks |
| | #4 |
| Senior Member | I think that you just need to keep changing the oil. If the oil is milky looking, then rub some of it between two fingers and see how thin it is compared to a sample of new oil. You don't want to spin a rod. That's your main concern. If the oil in your engine seems thick enough, run it, let the heat of the running engine burn off the remaining water inside. Since the oil is thin, don't rev your engine high until your oil looks good. Otherwise, there is a some chance that your head gasket is leaking now. So check your coolant in your radiator for traces of oil. In the weeks to come, check your oil level to make sure it isn't increasing and that your aren't losing coolant in your radiator.
__________________ "When the going gets weird, the Weird turn pro." - Hunter S. Thompson <a href=\'http://www.prebmw.com/clubsi/patwtf.jpg\' target=\'_blank\'>The sheer insanity that is Texas</a> <span style=\'font-size:7pt;line-height:100%\'>94 Milano Red Civic Si original SOHC engine 330K miles w/JDM LSD tranny, DC 4-2-1 header, ES poly engine mounts, OEM exhaust... tuned on a dyno w/Crome software by nfn15037 to 126 whp with 93 octane!!! 94 Stealth Grey Pearl GS-R Sedan 221K miles w/LSD 93 White DX Hatchback 145K miles... future rallycar 92 Charcoal Grey DX Hatchback 102K miles... future sleeper hatch 79 Silver Mazda RX-7 100K miles</span> <div class=\'quotetop\'>QUOTE(pissedoffs ol @ Mar 21 2004, 05:00 PM)</div><div class=\'quotemain\'> women + wheels = bad </div> |
| | #6 |
| Senior Member | Do you think that coincidentally, his head gasket is bad, and he's just noticed the watery oil... since he was checking out his car so carefully after going through some deep puddles? |
| | #8 |
| Senior Member | I just replaced the head gasket on the Si. No obvious white exhaust vapor plumes, but the engine was "producing oil".... and it was watery oil of course. The coolant level in the radiator never noticeably dropped though. I am so glad that my bf noticed the rising oil level last month. (Thank you Matt! And also for changing the head gasket!) |
| | #9 |
| Junior Member | i think its fixed....i called the honda dealer but there ass never called back like they said so i went to a local performance shop to see what they thought.....they said to look under the vavle cover and clean anything under there...well they were right .....we took a look at and there was a creamy white substance that was kinda thick. after having cleaned it out, the oil has cleared up...thanks to those who responded to my post... ian |
