what is an electrical load detector?
Old 07-29-2003, 06:29 PM   #1
import_racer is off the scale
what is the purpose of the electrical load detector? i get it at the odd times when i am at high rpms. when i restart the car, the cel goes away. also, i have a high pitched sound at the alternator at times, could that be the problem? thanks guys!
import_racer is offline   Reply With Quote
Old 07-29-2003, 11:50 PM   #2
anyone? also, what if i unplug it? would it run okay still? i read on hybrid that usdm cars dont have that feature.
Old 07-31-2003, 08:18 PM   #3
okay, forget the unplugging part. there is no wire there. what would cause my car to show a code 20?
Old 07-31-2003, 08:22 PM   #4
Jim Truett is off the scale
All Hondas have an ELD. It senses the load that the accessories and lighting put on the alternator, and sends a signal to the ECU. The ELD is one component that the ECU uses to regulate the alternator's output. It sounds like your alternator might be taking a shit, and the ELD is not seeing steady current passing through it.
Jim Truett is offline   Reply With Quote
Old 07-31-2003, 08:31 PM   #5
so it could be a faulty alternator? i dont have a stereo right now, used to. the cel comes on sometimes when i am in high rpms in third or fourth. the other times i did it in first or second, it never came on? Still think it might be the alternator? I hear a high pitch sound from the alternator belt at times. If that helps. Thanks.
Old 07-31-2003, 09:08 PM   #6
Please tell me you checked the belt tension before posting! If the belt is slipping, tighten it! That might be the problem. If the belt is slipping, the alt will have diminished output, and that may be the cause of the cel.
Old 08-01-2003, 04:58 PM   #7
i havent checked!! woops. how do i go about in doing this and adjusting the tension?
ELD ELECTRONIC LOAD DETECTOR arnold4 ECU's, Electronics, and Tuning 4 12-14-2006 01:28 PM
Electrical Problem With My 1986 CRX Si The_MATRIX General Tech and Maintenance 0 06-17-2004 05:08 PM
Basic Tire Info pissedoffsol General Tech Articles 0 01-12-2004 12:44 AM
ELD? Electronic load detector question afterburners ECU's, Electronics, and Tuning 2 11-21-2003 04:44 PM
Wheel Max Load Rating SpyOneUSN Wheels / Suspension / Tires / Brakes 7 05-10-2003 12:07 PM
