why is it not runing right
Old 11-06-2009, 07:01 PM   #1
Ride:  90 honda civic b-18
Rep Power: 1 little90 is on a distinguished road
Default why is it not runing right
hi i put a b18a in my 90 honda civic with a pr 4 ecu and stayded with the obdo set up it starts but runs like crap and when it warms up it starts to die could some one please help me with this problem
little90 is offline   Reply With Quote
Old 11-07-2009, 02:28 AM   #2
B
Administrator
B's Avatar
Ride:  318ti, dakota, genesis 2.0t
Rep Power: 403 B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
any CEL codes coming up?
was the b18a known good before putting it in?
Originally Posted by Airjockie View Post
I got plenty of duck tape, but no penguin tape...
B is offline   Reply With Quote
Old 11-07-2009, 11:47 AM   #3
yes oh and i put a pm6 ecu made a big diffrents stil the same code
and whats CEL codes
Old 11-07-2009, 11:53 AM   #4
mdpsEG's Avatar
Ride:  JRSC B20/vtec DC, Nissan Xterra SE
Rep Power: 43 mdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant future
CEL = Check Engine Light
if you have a CEL, check what codes are coming up.
do a little research man... this site has a ton of info. check out the reference materials for cel codes.
mdpsEG is offline   Reply With Quote
Old 11-07-2009, 04:25 PM   #5
the engine light is on and the code the ECU is popping up is 16 the injectors i just cant figure out what the problem could be ive replaced all the injectors man
Old 11-14-2009, 05:30 PM   #6
help i got a code 16 on my ecu ive check compression its 170 170 170 & 180 Ive change the injectors the main relay the resitor and still cant figure it out its a b18a with obdo componets can someone please help it does start and runs but sputers turns my plugs black like its getting to much fuel what could it be HELP!!!!!!!
crx d16 zc vtec runing problem Travisl HYBRID -> ED-EF / DA 7 10-09-2008 11:52 PM
What is the best Honda/Acura Engine for runing boost SunShine00 Forced Induction 39 08-03-2007 01:54 AM
Runing a chipped pr3 on my setup? Crix ECU's, Electronics, and Tuning 9 01-06-2005 12:30 PM
runing boost on p28, fuel management, and vafc... 5speed4life ECU's, Electronics, and Tuning 3 11-21-2004 03:07 AM
Runing a 97 gsr transmission on obd0 car.. Crix ECU's, Electronics, and Tuning 1 10-10-2004 12:44 AM
