wiring hrness extra clips
Old 02-14-2008, 11:10 AM   #1
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
Default wiring hrness extra clips
ok i just pulled the harness from my old engine and i started hooking it up to the new engine,,the problem is i have 2 clips left,,one down under the intake manifold and one down by the tranny...i also have a (green)sensor in the back of the block down towards the oil pan..is it normal to have left over clips/sensors??\
neither off the clips hook to the sensor though
wiring harness is for/off a d16a6
and its going on a b18a1
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 02-14-2008, 02:59 PM   #2
jlicrx's Avatar
the connector under the manifold is probably for the Fast Idle Control Valve on the Si - 2-wire connector with blue and black/yellow wires - the B18 doesn't have FICV like the Si - just leave it - what color are the wires at the one by the transmission? could be the back-up light switch? back-up light switch has 2 wires, yellow and green/black with bullet connectors - switch is on top of the D-series transmission and is on the bottom end on the B-series - the green sensor on the back of the B18 block is oil temperature sensor - you don't need it
ZCspeed Racing
Old 02-14-2008, 03:54 PM   #3
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
ok so the one under the im is for fitv,,,just remebred when you said something..and what will happen if i dont plug in the oil temp switch???
there are 2 bullet connectors by the tranny but there is also another sensor..ill try to get a pic
GOOD FAST CHEAP,
Old 02-14-2008, 05:53 PM   #4
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
what the hell is this?!?!it is right nect to the fuel rail on the motor...has a 3 wire clip on it
GOOD FAST CHEAP,
Old 02-15-2008, 09:41 AM   #5
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
any1??
GOOD FAST CHEAP,
Old 02-17-2008, 05:53 PM   #6
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
still wondering what that thing is
GOOD FAST CHEAP,
Old 04-04-2008, 01:39 PM   #7
91 ef/dx project
honda91efhatch's Avatar
Ride:  91 ef hatchback project
Rep Power: 4 honda91efhatch is on a distinguished road
looks like a plug for the dizzy?!?!?
honda91efhatch is offline   Reply With Quote
Old 04-04-2008, 03:31 PM   #8
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
def. not...there are 2 dizzy plugs,and the thing pictured is the egr valve
GOOD FAST CHEAP,
Old 07-08-2009, 12:52 PM   #9
Greenhorn
Ride:  90 Integra ls
Rep Power: 0 mattintegra is on a distinguished road
Question Same problem
I have the same problem. Cant figure out where they would connect to. Also have a problem with my b18a1. It starts after some spitting and sputtering. It idles fine at 1000 rpms. At around 3000 it starts sounding like its hitting the rev limiter. Anyone have any ideas what this could be? Could it be my EGR valve is bad?
mattintegra is offline   Reply With Quote
Old 07-08-2009, 02:24 PM   #10
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
Originally Posted by mattintegra View Post
i have the same problem. Cant figure out where they would connect to. Also have a problem with my b18a1. It starts after some spitting and sputtering. It idles fine at 1000 rpms. At around 3000 it starts sounding like its hitting the rev limiter. Anyone have any ideas what this could be? Could it be my egr valve is bad?
soundsd like a bad dizzy. You are in limp mode.
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 07-08-2009, 03:27 PM   #11
Neon Owner
cjvictoria's Avatar
Ride:  '04 NEON
Rep Power: 89 cjvictoria has a reputation beyond repute
cjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond repute
Send a message via Yahoo to cjvictoria
yo injen... i cant find the old valve covers thread... could ya help me out man? i just finished mine and it looks super sweet, but dont... well i just said it so, pm if you can help!
and wtf? i didnt know you were doin' a B series swap?! shit, very nice...
XBOX LIVE - jdmJO3
>>>Click ME<<<
I have D16Y7 injectors and fuel rail fo sale. pm me if interested.
cjvictoria is offline   Reply With Quote
ecu and wiring harness cx 8 valve to dx 16 valve gregzilda ECU's, Electronics, and Tuning 1 05-24-2008 01:24 AM
DSM 450cc injectors civic crx integra w' wiring clips RSS-Bot Auctions 0 11-18-2007 04:33 PM
94 honda civic to v-tech wiring HELP. cantbetouched24 Civic and del Sol - EG and EK 4 11-15-2007 10:28 PM
Need Help Wiring V-tech Extra wire to ECU cantbetouched24 ECU's, Electronics, and Tuning 3 10-19-2007 09:26 PM
crx fuel injection wiring went haywire! klacfyde ECU's, Electronics, and Tuning 7 07-24-2005 07:30 PM
