Need Motor To Go Into 96 Civic Dx
97hatchdx
looking for a motor to put into my car after MERLIN OIL CHANGE F**KED MINE UP.
hella bad knocking...either broken rod or bearing or something
anyway..looking for a motor. a d16y8 would be a nice swap in there.. id just buy the ecu and wire it up later
it currently has the y7 in there. slow ass pos.
would a d15 go in there? and how would i find a ecu for it?
either way i NEED A MOTOR BAD
where are you located?? and whats your price range..gotta gsr also, but shipping is always the price killer.
im located outside chicago. i dont really have motors to trade, but i do have a y8 head with about 40k miles on it. also im not looking for a motor with over 100k miles on it
got a 98 vtec motor and tranny with 75000 miles with a jackson racing supercharger asking $1000
does that include the engine management and ecu? if so ill take it
also how is the trans? and is the compression still good on all cylinders?
call me 8152097905 name is jason
yeah didnt know how bad you wanted a motor mines not that pricy but good luck
whats your price range?? im getting a d16y7 back from the machine shop tom. brand new internals and around 11:1 comp ratio, depending on thickness of head gasket. got screwed by co-worker and spent alot of time and money on it. just trying to get what i paid. its gota y8 head on it to.
yup tranny is included, just picked up the block today will take pics of it for ya
this is whats done;
bore-.025 over
crank micro polish
blocked decked 1 mil
complete rotating assembly has been balanced includes:
-pistons
-rods
-crank
-bearings
-flywheel
-clutch
-crank pully
the clutch is an organic street from F1
chromoly light weight flywheel from F1
if you use stock head gasket (3-layer @ 0.037 in) = 10.59to1 comp ratio
or use 2 ply (@ 0.025in) you get 10.91to1 comp ratio
and here are the pics
