help
91crx d15b2
:confused:whats goin on people.im new to this site.i have a 91 crx (d15b2) i want to do a mini me swap with a d16y8 head.will it bolt right on?what will i need to complete the swap and should tweek anything esle? i also wanted to put the d16y8 intake manifold on.what ecu should i use do i have to change the i have now what would be the best ecu to use? Is that the best head for my block.what kind of gain to you think i will get with this swap??thankx 4 your help.:confused:
DUKE
NEWCASTLE DELAWARE
DUKE
NEWCASTLE DELAWARE
Alright bro heres what you need to do. First is your D15B2 DPFI or MPFI. If its not your going to have to either swap your body harness or do the swap via the DPFI TO MPFI write up (you can find it on this site) or you can buy the engine conversion harness. Next your going to have to change your distirbutor. What ECU are you running now PM5, PM6? Your best bet is to go with a PM6 which is readlly avaible on ebay or somewhere in the parts for sale section on HS. Your looking at a pretty decent gain after the mini me. Good luck bro let us know if you need anymore help..
Ronnie
it is dpfi.. shold i do thisa swap before i put the vtec head on? can i use the p2p ecu for the vtec head? and what is a better head to use the z6 or the y8?
i would use the z6 head, do all of it at the sametime. use a p28 ecu and vafc to run the vtec. good luck man
can i get a parts list of what i would need? what is a vafc?
thankx
Search for Mini-Me write ups. This has been covered many, many times on the Internet. Don't listen to 91crxd15b2; he's a fucknut. You don't need a V-AFC...
You're telling him not to listen to himself. :confused: :)
Anyways, if you want to use the Y8 head(which btw, will bolt up); just remember to remove the oil jet/restrictor(look up Mini-me conversions). You'll also need to convert to MPFI; as all USDM B2's are DPFI, and you need a OBD1 or OBD2a/b conversion harness depending on what ECU you want to run.
Rywire can set you up with all the necessary wiring, you'll just need the ECU, distributor, and head. Good luck!
