:Economic Stimulus Time!! Memoryfab/Crower/Kirk Racing/JDM P8R Head..etc
xunchicrewx
here it is spring time!! and i have a shit ton of parts to unload i have accumlated over the years for my car, however im going in a slightly different direction this year. i can be pretty flexible on price cause in order to to get my car rolling again i need to sell these parts.. please PM or email me at xunchicrewx@gmail.com if you have questions. thank you!! i found out as of 6/06/08 i will be let go from my job due to company downsizing!! :cry:
*JDM Honda P8R Non-Vtec Head Worked by Port Flow and SuperTech Springs and Retainers. This head has 0 miles and flows similar to a vtec head. Port & Polish, Polished Chambers, Valve Work. For the price im asking your basicly getting the head for free with the amount of work done!! $1225.00 shipped
*NIB Memoryfab S68 Carbon Seat. This seat was one of mine i never mounted as you can see its still in the plastic. Our carbon s68s are on back order currently!! SOLD
*NIB Innovative DC/EG B or D Series Hydrolic Trans Replacement Mount Kit
part number 10150 and urathane stiffness is 60A SOLD
*NIB Professional Products 68mm Type R Satin Throttle Body
part number is 69067 and comes with the TB gasket SOLD!!
*SRR DOHC B16/B18 Adjustable Cam Gears in andonized purple SOLD!!
*NIB ARP B18 / B20 Head Studs
part number 208-4302 comes with all hardware $115.00
* NIB BLOX B18A/B20 Performance Intake Manifold
part number BXIM-10200 $165.00 shipped
* Crower Non-Vtec 404 Cam Shafts with AEM True Adjustable Cam Gears
used 10k miles if that.. Stage 3 - 3/4 Race, 1100 to 8200+ rpm, lope at idle.
Springs required. (18-21 hp) part number 62404-2 SOLD
*NIB BLOX B-Series Blue Cam Seals.
part number BXAC-00402-BL. price is for both... SOLD!!
* NIB P2R B18/B20 Thermal Intake Manifold Gasket and Hardware
part number 104 $30.00 shipped
* NIB OEM Honda B18B/B20 P8R Head Gasket
part number 12251-P8R-004 70.00 shipped
* B18B / B20 - P75 Chipped(uberdata/crome) ECU unit
this ecu was tuned for the crower cams above, the redline has been raised and the idle has been tuned as well as the fuel map. SOLD
* NIB Memoryfab EG/DC Driver Side Low Position Bottom Mounting Seat Rail
this was also an item from my personal collection that i never used. rail can be used with any bottom mount seat as well as OEM recaro seats SOLD!!
* Kirk Racing EG Civic Hatchback 4 Point Roll Bar
i personally painted this item flat green, has some markings from tires being loaded in and out, does not compromise the roll bar. rather heavy so pick up would be awesome!! only pic i have.. its still in the car 425.00shipped/ less if picked up!
*Buddy Club Spec II Exhaust(full cat back) 13 odd pounds of loudness and fury!
comes with silencer, however its still on the car and i wont be taking it off until i replace it first, and ill post pics then 350.00 shipped
_____________________MAKE OFFER SECTION!!________________________
*OEM B-series Clutch and Pressure Plate. This was taken out of my LS trans with about 30-40k miles but still has life left!! MAKE OFFER!!
*OEM 96-00 Civic EX Front Seats
these have been sitting in my garage for 5 years! just come pick them up.. IDGAF!
again if anyone has any questions ill be more than happy to answer and i can be flexable on prices but please NO LOW BALLERS!! the memoryfab products are sold and i only had 1 of each. thank you for viewing!!
How small is the Memoryfab seat? I'm 5'6/157lbs, and the Corbeau Forza seat is loose for me. Right now I'm looking at your seat and the Buddy Club P1.
the memoryfab seat is the same size as the P1 and stronger.. ive sat in the P1 and ive ran the memoryfab for years, both models(i work for them)
So should fit me well(same size as the regular P1s, correct)?
In that case, I'll take it. Do you accept paypal or would you rather have a bank check?
LMK, Kevin
in regards to the civic seats, where would i be picking them up from? how much did you want for them?
