eatsleepf22
i have a complete f22A motor i wanna put in a civic...but i was wonderin since the f22 and the h2s are alike what head can i use best for the f22 block..and also what intake manifold will be best..
any help is greatly apperciated and i not try to jack this thread
You can put an H22 head onto the F22 block if you want. Also, if you're just going to stick with the stock F22, you can use an H23 intake manifold to gain a few horses...
Isn't the F22A a SOHC engine? I didnt think you could interchange the heads of SOHC and DOHC engines.
Not all single-cam engines will accept dual-cam heads, but some will. You can swap blocks and heads between pretty much any of the H/F-series engines. An H22 head onto an F-series block isn't a bad idea actually; you get the H22's VTEC and better flowing head, plus you eliminate the H22 block's FRM sleeves, which is a weak point when it comes to boosting...
Interesting, thats good to know.
