b16a swap done, now loose steering
JAKracing
well i just finished up my swap, so i took it down the road, i got into it a little bit, when i change from 2nd to 3rd, the car nearly changed lanes. it scared the hell out of me. so what is wrong? does it need to be aligned or what?
could have been anything.
more power, loose lugnuts, needs alignment, loose axles, road ruts, flat tires...
no lsd, it only does it at like high rpms, or when i hit a bump in the road. feels like alot of play in the steering. i dont' know
get an alignment first. then let us know. you should need one anyway since you fiddled with the front suspension some doing the swap.
