jdm_rb20_h22a
Adrenaline_Junkie!!
Ok..as you can guess by the title, I have a jdm H22A in my 92 Prelude (with the governed jdm ecu) and I am getting code 12 after engine warmup. The car is verrrry drivable and seems extremely fast, but it will NOTTTTT idle on it's own. I have to apply some throttle in neutral or actually be driving.
I drove the car with NOOOO problems without VTEC wired up for about 2 months. Within a day of VTEC'n-it-up, the Code 12 started showing up and it would die after warmup. This happened at random times, sometimes after an hour of highway milage (smooth driving).
NOW: It will rarely ever hold an idle on its own. I always have to hold the gas pedal to keep the rev's up or keep it in gear (accelerating or decelerating), AND I get a code 12 EVERYTIME after warmup.
so my question: Does this fact (that it WILL NOT HOLD AN IDLE ON ITS OWN) tell me or anyone which part I should replace first?? If I understand correctly, a bad egr system is pretty much a wide open vacuum leak, so I am hoping that a constant-dying problem is going to point to one of those parts over the other one..
I already have the FSM but I am a "backyard, sparetime, sparemoney mechanic" and I don't have the vacuum-testing equipment, the time, or much money for guessing
Thanks so much from a new member!!!
--TJ
--TJ
