yes it will but you will need to use the flywheel and clutch also from the eg , and the ef tranny is a cable tranny and the eg tranny is hydro so you will have to convert your car to a hydro clucth or buy a kit from hasport to get around it.
yes it will mount, but you will have to get all the pluming clutch master cylinder and all to do that. if i was u i would just look for a 88-91 si tranny, it will save you some money in the long run
one junkyard here where i am is selling a dx tranny for 150 and an si for 200. but this other junkyard is selling there trannys at a flat rate of 75 dollars but they only have an EG and integra LX. and i don't even have a budget right now
hey this might be off topic but does a b16a motor have the same mounts for my ef? cuz i'm jus trying to bring the car back alive before i do anything performance wise cuz i wanna see if the cars still worthy enough for an engine swap.
Any D-series engine will swap in with stock mounts and bolt to your transmission. Anything else (B-series, K-series, F/H-series) will require different mounts and a different transmission...
