d16y7 to d16z6?
broonie86
hi i have a 98 civic coupe which had a d16y7 engine until a conrod gave way and went through the block :(
i have a complete d16z6 engine but no wiring loom for it, i know the engine fits in the car but i dont know how to wire it up with my car, am i right in thinking that i will need a p28 ecu and add a few wires so that vtec will work or do i need to do a bit more than that?
if anyone can help on this it would be greatly appreciated as i need the car on the road asap
thanks
broonie
You'll need to either convert the engine to OBDII or the car to OBDI.
I'd just use a D16Y8, personally.
ok how fo i go about converting the engine to OBD11 as i dont have the loom for the z6
do i just change the dizzy and ecu then wire in vtec to my loom?
im hoping to do this this weekend so need help asap
thanks
broonie
ok sorry i didnt search before i posted but i have very limited net access at wiork and i work 12 hour shifts, so only get online at weekends
anyway ive been searching around for a couple of hours and as far as i can see all i need to do is put my loom on the z6, add wires for vtec and wire into the z6 ecu and get a ecu jumper pack and all should be fine :)
am i correct with the above?
if it makes any difference it is a uk car ;)
need this done asap as the crx is getting the b16/b20 combo put in at the moment :D and my daily runner is out of mot next month and wont pass another so need another car now
cheers
broonie
yes your correct, just plug the harness in as usual then order a obd2a-obd1 jumper harness, then cut the wires for the vtec sol and vtec pressure switch and run them into the engine bay. then just plug the p28 in and it should work. oh yeah and the IACV needs to be converted to two wire instead of the three wire on obd2 cars.
sounds simple :)
where is the best place to get a jumper harness in the uk?
thanks for the help, been reading through the forum and it seems a very good, helpfull site
broonie
www.rywire.com is a good source.
in regard to your car being in the UK, i'm wondering.... is your coupe right hand drive like your crx? i don't know off hand if there's a difference between a left hand drive engine harness and a right hand drive harness. anyone know?
Right-hand-drive harnesses are opposite compared to left-hand-drive harnesses. That's why people generally modify their stock harnesses when they swap in JDM motors rather than attempt to use the left-hand-drive harness...
That's fine that the plugs are the same. The wires are not ment to route the USDM direction tho.
Thanks Brutal, that's what I was assuming, but didn't wanna be an ass :)
yeah my coupe is a right hooker like my crx,
so is there a difference between a lhd and a rhd for the jumper harness?
cheers
broonie
ive managed to get hold of the wiring loom for the z6 but ive noticed that unlike my y7 loom the z6 loom doesnt plug straight into the ecu, is there another part of the loom i need to get before i can use this to plug into a p28?
cheers
broonie
your supposed to just use the y7 harness and add the two wires for vtec
i have both looms here but i think i have to change a few wires around as the inlet manifold is completely different on both engines and a few plugs look different
cheers
broonie
should be a 2 wire IACV glug instead of the 3 wire on the y7. really shouldn't be that hard if you just start plugging the sensors up and once you see one that doesn't fit just swap plugs.
