HATCHET_HONDA
scottie fizzle
swappin a b16 into my 91 dx.... i have a spare d15b dizzy and wondering if itll work for the b16? its an obd1 vtec dizzy so i figured it would..tryin to save a lil cash by using spare parts
Ah, it might work. I think I tried/still have a D-series dizzy on y B16, or atleast the coil pack from a D in it. Try it if you have it, it doesnt cost anything to try and see.
d's have a different firing order than b's do. the only way to use one is to use a zydne ecu, their "one-wire" conversion ecu lets you use a stock si distributor (it bolts right up to the b) on a obd0 b16. some of their obd1 ecu's may do the same, but i doubt it, as the one-wire ecu was designed just to make swapping early b16's into ef's easier.
Huh?
1-3-4-2 on both.
