Transmission/Motor swap question
oltrout31
Will a transmission from a 93 integra work on a 95? If not will the motor from the 93 fit into and work in the 95?
The motor yes, the transmission no. It will physically bolt up but the 90-93 uses cable actuation and the 94-01 chassis is set up for hydraulic clutch actuation, so you'll either need a hydraulic transmission or a conversion kit...
are u interested in selling ur integra and useing the money to start over?
yo i would like to know what front wheel drirve transmission would fit the f20c engine?
Car building project !
it must have lsd to go with the transmission
First of all, start your own thread if you have a question, don't jack somebody else's.
As for your question, there is no FWD transmission that will bolt up to that motor. If you had bothered to research this at all, you would know that...
