i dont see how that is.. its 1 bolt holding them in..
1st.. fold down the rear seats and lift the trunk carpet.. you'll see a 12mm bolt towards the middle somewhere, take that out..
2nd.. to remove the top section, grab the top of one of the cushions and pull it to the side and it should release from the inner post.. same goes with the other side..
3rd.. now back to the bottom cushion.. now that the tops are out of its way.. lift from the rear towards the front.. there are 2 clips on each side of the cushion.. you'll have to maneuver it a bit, but they'll come out pretty easy.. hope this helps..
