Just getting my FS thread started. Little bits and pieces will be added upon the way. Here we go.
PAYMENT METHODS: Paypal preferred, contact me prior to sale if you don't have a confirmed Paypal address, and we will see what we can work out.
PRICES: Are negotiable, unless otherwise stated.
SHIPPING: Will be standard shipping service (ground) unless you want to pay the difference. USPS or UPS.
PARTS ARE IN WORKING ORDER, UNLESS OTHERWISE STATED.
TRADES WILL BE CONSIDRED, LMK WHAT YOU HAVE!
Ok, here's what I've got:
96-98 Civic Projector stlye Headlights. Working condition, the only thing that doesn't work is the ring around the brights. Minor scratches, overall OK condition.
PRICE: SOLD TO LUIS998
Gauge Bezel from my EK. Great condition. NO scratches or cracks.
PRICE: $10 + Shipping
OEM B-Series clutch, flywheel, pressure plate. In working order when pulled from my EK. Used on a B18B with a B16 tranny for ~10k miles with no problems (clutch had been used prior to this, unsure of total mileage)
PRICE: $20 + Shipping
AEM B-Series Ram Air Intake tube. No filter included. Painted red to match my valvecover.
PRICE: $15 + Shipping
OEM B18B1(OBD2) Cams & Cam gears. In great shape. Less than 40k miles when pulled from my engine. Have been in a box covered with rags and bags since.
PRICE: $75 + Shipping
Virgin OBD2 P75 ECU (Manual Transmission). In good shape. Worked when I removed it from my hatchy. Small dent, but still in good working condition. No chips, unmolested.
PRICE: $50 + Shipping
EK Gauge Cluster. Manual transmission, 170,303 miles. Works perfectly. Needs bulbs because I removed them for my new cluster. NO SCRATCHES, NO DINGS, NO DENTS. Perfect shape.
This is what I believe is a newer Civic Si (guessing 01-05 or something) Gauge Bezel with two housings for standard 52mm gauges. Brand new, never used.
A-Pillar w/ 3 spots for standard 52mm gauges. This came off of a 92 Accord. Not sure what else it will fit. In decent shape, not too beat up.
PRICE: FREE - You pay shipping.
Stock OBD2 B18B1 injectors. Work great, no seals included.
PRICE: $45 + Shipping
OEM B18B1 Oil pump (painted black). This worked when I pulled it from my motor.
OEM 1996 Civic fuel pump. In great working condition. Collector included, as well as the hose on the end of the pump. No wiring included.
OEM B18A1 Cams + Cam gears. These were not from my engine so I'm not sure how well they worked before. So I'll let em go cheap.
PRICE: $25 + Shipping
OEM B18B1 pistons and rods. Pulled these from my engine. Less than 40k miles on them, and they show it. Perfect for a rebuild, just buy new rings and bearings. Caps included but not pictured. Caps are also in excellent shape.
Set of OEM head bolts from my B18B1. In great shape, nothing is stripped.
Cant remember what this is called. I know it houses the crank seal. Its from a B18A1 that I stripped. It looks to be in good works, but I'll let it go for cheap.
PRICE: $5 + Shipping
OBD2 P2E ECU (For D16Y7, manual transmission). This ECU is in EXCELLENT shape.
PRICE: $30+ Shipping
Complete D16Y7 that I have had lying around for awhile. It has ~170k miles on it. Its extremely clean and was meticulously (sp?) maintained by my dad and I. Oil changes every 3,000 miles with full synthetic. It has been sitting for about a year, but everything is there except the slave cylinder for the clutch. PARTING THIS OUT, UNLESS YOU WANT TO PICK IT UP. Let me know what all you want from it. I have the complete engine, tranny, axles, shift linkage, some of the mounts, intake mani, exhaust mani, etc.
PRICE: ----
Set of EK taillights. Fake carbon fiber, but they don't leak.
Volvo TDO4-12B turbo from my 89 760 wagon. This turbo needs a rebuild. The bearings need to be replaced. Shaft play and it leaks oil out of the exhaust and into the intake because of this. Comes with Wastegate, BOV as well as the complete turbo.
PRICE: PENDING SALE - AWAITING MONEY ORDER FROM WATKINSCRX89
B18A1 Intake manifold. In good shape.
PRICE: SOLD TO GEORGE777
B18A1 Distributor. Don't know if it works or not.
PRICE: FREE - You pay the shipping.
B-Series rear "T-Bracket", in good shape.
OEM B18B1 Exhaust manifold. In good shape, minimal denting on the bottom from my hatchy.
OEM B18A1 Exhaust manifold. Kinda hard to see in the pic but its in decent shape.
OEM B-Series stock axles. In good shape, no torn boots.
PRICE: $20 + Shipping (These are gonna be a bitch to ship)
OEM EK Civic Hatch rear wiper motor - works and wiring is uncut!
Wooh, thats it. Questions? Email me at mnichols04@gmail.com. OR reply here, I check HS regularly.
kthxbai
PRICE: ----
kthxbai
