obd0 to obd1 swap
electric_rex
i have an odb0 to obd1 conversion harness, and i changed to a 4 wire o2 sensor but i was wondering if i had to use obd1 injectors because the conversion harness instructions mention nothing of it and if i did have to use the new injectors(which im not sure i do) how do i get rid of the injector resistor box(which i hope i dont have to)?
Does obd1 has any advantage over a obd0? I have a B16A DOHC Vtech, from japan vetech chips in at 4900 RPM running on a OBd0 Am i Loosing any power, if i converted to abd 1, would my car have more power, I am new to honda swap, can Pm please dont understand how to check response in open fo
Uhhhhhh, no.... In my opinion its the best version to go with as far ar tunability and compatibility, lotta options for an obd1 setup.. alotta people actually downgrade to obd1 from obd2.. If you get it chipped, a good engine managment system like Hondata, motec, F.A.S.T., Neptune.. something along those lines.. then you'll be on the right track.. but none of thats gonna do you much of any good unless you build you a motor to tune in the 1st place...
Vetech, what the hell is that!
