Its been...
well over 8-9 years since I last painted anything, but here are some tips from when I painted my engine bay.
I used about 2 gallons of Paint prep/alcohol based cleaner to get all the years of Oil, silicone spray, and I believe the original owner added Simonize to the paint...which turned to yellow. After the cleaning, my engine bay looked brand new, but since I was chainging the color, I repainted anyway.
Use red scotchbrite like someone mentioned before. Sanding in an area like an engine bay is very tought considering all the contours that are in and about that area. The red scotchbrite will form to whatever surface you are trying to scuff. its better to have a good scuff, than a mediocre sanded surface. Add spot primer to any bare exposed metal. Dont primer the whole engine bay, unless you want to resand the engine bay again. People may disagree about not primering the entire bay, but most cars never had the engine bay refinished before. The factory paint makes a good bond surface as it has already been prepped properly at the factory. Use 320 if you like, but nothing lower. Anything lower will reveal sanding marks. 320 and red scotchbrite will leave sanding marks as well, if you dont use a sealer. Paint sealer should be applied before base coat. Flash times will vary between different sealers.
Apply base coat, then clear the crap outta it. I too painted my engine bay black because at the time, I did not know what color I wanted to paint the car. A black engine bay makes it look deep and less cluttered. Add more cleared to more exposed areas like the radiator support (upper tie bar area), shock towers and fender rails. They will be the areas that are most viewed, so a high gloss finish there will show off more. Lower firewall areas, lower frame rails will be hidden by the engine and transmission.
Feel free to critique anthing I have written here. Again, its been quite a few years since I even held a paint gun, and Ive had a few beers before I wrote this.
HTH
- J
For the last time, this was about 8-9 years ago...so no talk about why I didnt do a wire tuck!
