aftermarket steering wheel..no horn?
HATCHET_HONDA
scottie fizzle
i installed a momo steering wheel on my 90 civic hatch..is there a way to keep the horn? i had to disconnect the copper tab on the colomn cause it would make contact with the hub adapter and the horn would go off when i made a turn,, any suggestions?
touching the middle ? could th wire be too short ?> and when you turn its getting pulled tight ?
just a thought !
just a thought !
the wire isnt the problem its the copper contact tab..ok, the factory wheel has a copper ring on the bottom that makes contact for the horn..well the new hub is ALL metal so not only does it touch the bottom as its supposed to it also touches on the center of the hub when the wheel is turned..thinkin of just unhookin the tab and sayin fuck it
This is my horn:
just an update....i recently chucked that shitty ebay hub adapter and have installed a quality momo brand hub. whattya know..my horn works fine!! has been for like 5 days now...sometimes you get what you pay for i guess
glad you got it fixed , but your right at times you do get just what you pay for
