& an upgraded ECU, otherwise it would be dead in 6 months
wow since you have no clue wtf you talking about dont post anymore just learn.
He has a 95 which still makes him obd1, there is no upgrade to the ecu that he needs to do. thats done by a tuner who knows what hes doing. they will pull your ecu out and put a new burnable chip in it. Then tune the car so the fuel and timing maps are up to par with the new amount of power your putting out with the motor.
I didn't go into detail with a turbo set up but if you decide to go that route you are going to need
turbo, turbo manifold, down pipe, high flow cat, cat back exhaust, wastegate, bov, boost controller, intercooler, intercooler piping, intercooler piping clamps, oil feed and return lines for the turbo, larger injectors around 550cc or 660 cc, vacuum lines, misc t fittings, boost gauge, The stage 3 clutch like i mentioned above.
How you car runs afterwards depends on how competently you rebuild the motor, and how good of a job your tuner does tuning the car.
btw I have a t3/t4 5bolt stainless steel 3" downpipe with flex pipe for sale, pm if interested
