What axle for gsr tranny with quaife
deadazleep
installed a new flywheel on my b16 with gsr tranny, discovered that both axles were in need of replacing. Drivers side was no problem using a b16 axle but the passenger side didnt fit up correctly, took the axle out of a non lsd b16 tranny that had no problems but it wont seal properly, When placed side by side my busted axles splines were shorter going into the tranny than the normal b16 so it would leak out transmission fluid. The car came with the swap so my question is what axle should i buy for it since i cant seem to find anyone localy to rebuild it
i used one of my buddies spare axles that he had just pulled outa his b swapped eg hatch like mine and it would work but the axle would slide out jsut enough to let transmission fluid out
the integra axles are a tad longer than b16 axles..
just the splined end? i wish i woulda took a pic but the part of the axle that goes into the tranny on mine was slightly shorter than his gsrs he's using on his b16 tranny, by about a quarter of a inch. so ur saying a real b16 axle should be the way to go, and for a b16 del sol or a 99-00 Si? sorry wish i woulda been around when this car was put together so i would know first hand.
88-00 with b16a mechanical parts 94-97 del sol doch vtec
92-95 b16a electrical parts 94-95 del sol doch vtec
96-00 b16a electrical parts 96-96 del sol doch vtec
94-01b18c mechanical 94-01 gsr
hope this helps
might have to get an axle for integra and one for a del sol
so ur saying since the integra axle works on the drivers get a dohc del sol on the passenger?
