Help Installing 90-93 JDM Head lights
salvadorrivas13
Hey guys, ive been searching for a way to install my JDM headlights on my integra. I found 2 links on HS but i dont really understand them. Im kinda slow I was wondering if Any one knows a Link, or If you guys can tell me a Step by Step instructions. I would gladly apriciate it thnx.^_^
Aren't they pretty much the same as the USDM headlights, except the corner lenses are attached?
what do you need help with specifically?
it goes like this.
go to the junkyard and buy 2 headlight plugs from any 92-95 civic. they're H4's and they're a direct plug in for the headlights. JDM 1 pieces use h4h's. h4 = h4h as far as the plug goes.
remove the corner lights from the front bumper
12" extension (2-6" extensions) and a 12mm socket w/racther remove the bolts holding the bumper on.
remove the front bumper
remove the 2 10mm lower mounting tabs on the core support which attach to the headlights
remove the 3 10mm bolts along the top of the headlights.
unplug all the lights and shit.
remove the lights.
splice the h4 connectors on, the wire colors are the same. Use solder.
Hopefully your JDM lights came with the lower brackets and shit already.
Installation is reverse of removal.
it goes like this.
remove the lights.
Ok i got the wires and bulbs from the civic yesturday. Know im tripping cuz when i was changing the fog lights i didnt see any yellow capsules. You think i could put the capsules from the Acura Legend? Oh, and the lower brackets you talked about aint there. This sucks dude, ill probaly find some metal strip or something.. Hu?^_^
heres a pic of the lights, can any tell me were i can find the plastic cover the one that goes on the headlight beam. as you can see im mising one. shit, hey atleast i got these for free. ^_^
OK finaly, i opend the JDM lights and put the capsules in, but the legend holder dosent fit! lucky me it had one in there i only put the yellow glass and spring. know i figured everything out. its going to be hella sick. but first i have too restore the lights cuz it has sun burn haha. any ways thanx for your help. god bless my MECHANICS. its true you guys are my free of charge mechanics. thnx guys talk to you later with more problems soon LOL j/k......=)....Im so corny Hu........ok bye............=)
