So California: FS Built 1995 Honda Dx
Johnnylawless
Fully Built 1995 Honda DX:
MOTOR: (1600 miles on rebuild)
B16a Sleeved with GE HD Sleeves, to 85MM
Wiseco 10.5:1 85MM Comp. forged pistons
Scat Forged B16a Rods with ARP studs
Factory Honda crank and rod bearings
ARP Crank Studs
750CC RC Fuel Injectors
Type R piston oil squirters
Type R oil pump
Type R Water Pump
Type R oil cooler
Type R oil pan (extra ½ quart oil capacity)
Type R harmonic dampener pully
Type R Alternator
Type R fuel rail
Type R ThrottleBody
Type R Head
Type R Cams
Type R Distributor
B&M CommandFlo Fuel Regulator
AEM TRU-Time Cam Gears
Type R Transmission (has 300 miles)
Stage III Gator Racing Axles
Custom EGR Kit.
TURBO KIT: 600 HP Custom Kit
Turbonetics, Stage 5, 62-1 Turbo, NO shaft play (1600 miles on entire kit)
4” Inlet!!!!
Stafford Fabrication Custom Manifold (no bracing required)
#3 runner tapped and fitted with EGT Sensor, car comes with EGT Guage
Custom 3”>2.5” Downpipe with 02 bung
Turbonetics Evolution Wastegate With shims and all springs (dumped to Atmosphere)
HKS SSK SuperSequential Blowoff valve (has Purple Valve insert)
Greddy Trust Type 31 Intercooler,Inlet,Outlet Modified to
2.5" Exhaust back to MagnaFlow Muffler
AEM ECU wired to AEM WideBand O2 Controller, allows on the fly tuning
GM 3 Bar Map Sensor
New Brakes all around with Braided Steel Lines
Fluidyne 1/2 Bay Racing Radiator
Car comes with:
Boost/Vacuum, o2, Tach and EGT Guages
Also full sound System,
clarion brb-5475
Kenwood 6" coaxial speakers x4
MTX 12" Subs x2 in box in trunk
600 Watt dedicated Sub Amp.
MANY,MANY Extras and Spare
Parts
Asking $12,500 OBO
No LowBallers, Serious offers only
http://http://i170.photobucket.com/albums/u276/Johnnylawless_photo/Car%20Sale%20Files/DSC01634.jpg
http://i170.photobucket.com/albums/u276/Johnnylawless_photo/Car Sale Files/CAR001.jpg
Put this on av-imports.com. you might get a local to swoop it up from you...
