StupidSlowEG
n00b
I bought a y8 head for a6 block and now i need a vtec controller, but i dont know which one is recommended so i was wondering if any one could recommend some v-tec controllers thanks guys
Indeed. VTEC not only uses different fuel maps than non-VTEC, it also uses different timing maps. While an ECU hack might do a semi-decent job of tricking the ECU into the fuel corrections it won't do anything about the timing tables.
The cam gear will help with mechanical timing. Blanco is speaking of ignition timing...Hey Scott, I think this question might be on the subject. Whenever doing a mini-me, should one use an aftermarket cam gear in order to help adjust the timing?
Also, why would one opt to use a B-series ECU on a D? Is it because of what you stated, that "your engine will have more fuel and timing in VTEC or it will blow up?"
^^^What they said.
Using the PR3 ECU will provide better timing and fuel maps than any non-VTEC ECU and you can use the hack to trim the fuel in VTEC a little...not that I'd choose this route with my engine. We pretty much know the dangers of running lean, too much heat and ka-boom. Running rich can actually do the same thing. The extra fuel washes the oil off of the cylinder walls, which creates excess friction, which creates heat, which goes ka-boom. A D16Z6 or Y8 ECU would be the best option, but that would require not taking a 15 year old short cut. We're extremely fortunate to have the tuning tools we have because most makes don't have them available. For example, the same tune that would cost us about $150-300 would cost an E36 BMW owner $1100-1400. Why not take advantage of the tools available? BMW owners resort to spending $350 for a generic basemap chip for their listed mods. Why not take advantage of the tools available?
As EFHondaKid said, putting a 1.6l cam over a 1.5l block (other than the D15B VTEC) will advance the timing by 4.5* (half a tooth) so you need either a Y7/Y8 or adjustable cam gear. The key way location on the Y engines in 4.5* retarded over the '88-91' D16 engines. Important note: I often get the advanced/retarded part bassackwards, just know that either way it does redegree the cam/valve timing back to "zero".
Either or... Any configuration of a 'frankenstien' motor weather it be D-Series or B-Series have slight cam timing problems. Think about it, you're taking two motors to make one motor... it's not gonna fit like a glove...You said a 1,5 L block I have the a6 block isnt that 1.6 L
So i should just scrap the contorller and get the obd0 b16 ecu?
B16Racer and Scott....thank you guys. I was able to rep both of you. Byron, I tried, but I have to spread it around some more.
I'm thinking that with my inexperience I will be better off not doing a mini-me.
