Great...just great.
efhondakid
My name is Byron.
I feel like a noob here but I would just like some opinions on the following problems.
1. Fuel pump isnt coming on. (Brand new pump last summer.)
2. Main relay clicks really loud. (Brand new today.)
3. Solid light on in the ECU.
Any help would be greatly appreciated.
wiring..dont know exactly what but sounds like wiring
I was waiting for that answer.:lol:
The funny thing is the car has been running for about a month and I finally went and got it from my parents house yesterday and on the way back to my place it just quit, and the fuel pump isnt coming on.
hmm maybe the pump went bad??
get a test light and check to see if its getting power..just pull up the back seat and test both wires
Ok so I reset the ECU and the solid light is gone and I can hear the FP coming on now, but it still wont start.
check the fuse box in the engine bay and look for the ECU fuse i think it a #10 wen the ECU fuse is out i causes the same affect. Wen the fuse is blown their is no signal to the main fuel relay, and from the main fuel relay theirs no signal to the Fuel Pump causing it to just crank. ^_^
That fuse was blown, but I think its not getting spark for some reason. This is pissing me off so bad, the thing ran fine until I got a block from my house yesterday, do you think the dizzy took a shit?
if there is no spark then thatd be my first guess
ECU-good
Fuel pump-good
Relay-good
Fuses-good
Dizzy-junk!
Swapped out my dizzy for the extra my friend brought over and it started right up.:D
this furthers my argument that honda distributors are inferior to pretty much everything else on the car. glad you got her running ^^
Congrats for getting her running again...if its obd0, I know those distributors are a little harder to find.
I got a brand-new one from Rywire - Online Store when my original one went out, haven't had a problem since!
ECU-good
Fuel pump-good
Relay-good
Fuses-good
Dizzy-junk!
are you using aftermarket plug wires?
and rather than buying a whole new distributor, get a new igniter from honda and rebuild your old one, the igniters in aftermarket distributors usually only last a few months.
No. The ignitor controls the coil...they're two different things.
OE plug wires why?
And Im going to rebuild it, well my dad is because I dont have any tamper-proof torx bits. The spare dizzy that my friend brought over was from a D-series, and when we put it on it was sooo advanced to get it to bolt up he was like "Its not going to run like that." but we just used it to see if we would get spark from it, tried it and the thing started on 3 cylinders with it being super advanced. We also tried to swap the coil first and that wasnt it, so its either the igniter or another internal sensor.
