First off... I've searched all of hondaswap's forums b4 i decided to post and I couldn't find ne related topics sooo here it is....
Soooo my problem is that I have a 5 gen civic ex with a gsr swap. I took the swap out of my crx which was converted to obd1. I bought an ls (s80) tranny and all required parts to do the swap. I have a p72 ecu chipped by jet and it worked fine b4 i took it out....I havent installed the iab or the knock sensor yet but it shoulda started . it started up in the beginning but it was running only on 1 cylinder.... I found out water got into the other 3 spark plug holes (no water in the cylinder) so there was no spark... and now it won't start at all...!!!! I don't get no spark or fuel and I don't know why..
Since then I've changed the ignition coil, icm, wires, and spark plugs..... i changed the fuel pump and relay and also checked all fuses.... I even tested all the removed parts and they started right up in another civic ex.... really stumped and don't know what else to think of... Can it be hydro-lock? ( I don't know how that can be) Can ne one help???!?!?!?!
