All u b20 VTEC owners!!
89vwfox
What kind of hp are all of u putting down to the wheels post your setups!!
1990 Civic SI
b20 block
j1 transmission
gsr head p&p
Skunk 2 cams, cam gears, valves, valve springs, titanium retainers, intake manifold,Tb.
Bolt-ons
Build Will be done soon. Watch out for those you tube videos!
with gsr hea, lightweight crank, eagle rods, 84.5mm pistons, stage3 cams, aluminum retainers, dual valve springs, flat nitrate valves, comp keepers, p&p on head and intake, flywheel, all lightweight pulleys, electric water pump, etc, over 130 to wheels
I hope you put 130 in there by accident...
