IL 1992 Honda Civic CX, LS Swapped, tons o goodies!
Dasfinc
Details: 110K miles on the body, 77K on the motor.
Car is a 1992 white Civic CX with Blue interior, It has a 1996 B18B1 swap, Plug and play swap (only wires clipped anywhere on the car I re-connected and that was on the Strut-tower brace from my old SOHC Mini-me setup)
Car is running a OBD1 PR4 ECU, and runs STRONG.
Car has only had this motor for the past 3000 miles, and had one trip to the track (was towed there and back) where it ran a 15.6 @ 86 with a 2.3 60 foot with me letting off early (Got an 89mph trap later that day, but only got a 15.7). I'm sure the car could break into the 14's with new rear struts, and probably some better tires
Transmission shifts PERFECTLY, motor runs Damn near flawlessly, and it has a TON o work into it:
Car has:
1996 B18B1 motor
1996 LS Trans
Black with blue speckle Delsol seats (Seats are flawless)
GSR Shift knob
LX MANUAL gauge cluster with 6500 redline tach (I retained the origional Speedo to maintain the miles)
Hyper-White headlights
Amber corners
B+M Short Shifter
Poly shifter bushings
New Radiator
New upper control arms
new Upper Ball joints
new front brakes (Pads/rotors/calipers)
new lower ball joints
new outer tie rod ends
new spark plugs
new spark plug wires
new fuel filter, both in tank, and under hood
2.25 Test pipe, and Cat-back into a Cherry Bomb Turbo muffler (Regular oval muffler, painted flat black)
Intake
newer battery
255lph Walbro Fuel Pump
AEM UEGO Wide-Band O2 sensor and gauge mounted in single gauge pod on A-pillar
B+M Fuel Pressure regulator
old-school Solid HASPORT motor mounts
16 inch rims (I haven't identified them yet, I've been told they may be 'sparkle' rims due to their age.) on a fairly worn set of P205/40/16 tires.
the bad:
Ugly, City car so could use some TLC (New drivers fender, hood, paint job, rear bumper)
Fuel pressure isn't reading right, Car runs fine, I suspect the gauge is bad
IACV is dirty (occasional idle 'lope' at stoplights, again, will probably deal with this soon)
Price is $2500 Located in Northern IL. (Ottawa IL, 61350)
My name is Dan, my number is 630-857-6625
http://s26.photobucket.com/alb...5.jpg
http://s26.photobucket.com/alb...6.jpg
http://s26.photobucket.com/alb...7.jpg
http://s26.photobucket.com/alb...8.jpg
http://s26.photobucket.com/alb...9.jpg
http://s26.photobucket.com/alb...2.jpg
http://s26.photobucket.com/alb...3.jpg
http://s26.photobucket.com/alb...4.jpg
http://s26.photobucket.com/alb...0.jpg
CAR IS A 2 OWNER CAR!!!
Was purchased BRAND NEW in 1992 by my father, and it was given to me in 2006, noone else has TOUCHED this car but me and my dad
Okay, I'm interested. I'm moving to Minn on the 11th of August from Indiana.
Where exactly are you?
Nevermind, just found it (Ottawa). Now I just have to run it by the wife, and you might have a sale!
I have a 1993 b18c, and a 1997 Volkswagen Jetta Jazz. The Jetta doesn't get better mileage than the Honda, so might as well have 2, right?
Yea, all the people who I know that have VW's complain they don't get crap for MPG if they are gas powered.
The car was daily driven until I bought my Fiance her own truck, and it was getting 28mpg mixed, and 30+ on the freeway.
Yeah, mine is getting about the same. Long distance interstate trips @85mph yield 33.5mpg.
