The teg radiators are taller than the ef radiators. It's not gonna fit... The size difference in the inlets and outlets between d series and b series aren't so much of a difference that a leak should be a cause of concern.if your radiator is in good shape, you'd be better off taking that as well, as it will have the correct size inlet/outlet for the B's hoses.
axles yes, midshaft no...can axle and midshaft from an auto tranny fit on a manual one cause the tranny in the teg is auto
