Wastegate solenoid
awptickes
unimpressed by you
VIP
Ok, so let's say I have an extra EVAP Purge solenoid. I can use this for a wastegate control solenoid, correct?
Anyone know how much pressure can build up in the civic gas tank before something blows?
Well, I just tested it at 50PSI while closed for 12 hours with 0 leakage. I think it'll work fine.
Damn those little things will hold 50psi.:eek: So how do you plan on using it to actuate the wastegate?
