how much psi can I boost??
turbosivtec
Yeah I was wondering, whats the max boost i could push with my d16a6 motor?
specs:
stock internal
450cc injector
greddy td04 turbocharger with internal wastegate
jdm intercooler
afc tuning, stock ecu
so right now Im boosting 6 psi and I wanted to push more.
whats the max i could push it to be safe:
any info thanks
I'd say about 15psi before you blow something. That's pretty normal for D-series.
jdm intercooler
RLY? What's a JDM intercooler look like? Is it different than a USDM intercooler? Oh, nevermind, I know. The JDM intercooler exits on the right side, right?
Lose the greddy e-manage. It's a good way to fuck up an engine.
specs:
stock internal
450cc injector
jdm intercooler
any info thanks
How about you just leave it at 6?
leave it where its at, get rid of the hack and get your ecu chiped and tuned properly, that piggy-back will end up blowing your motor. psi means nothing, you need to figure out how much cfm your turbo is putting out, a t-25 at 15psi will put out as much cfm as a t3/t4 60trim at 7psi, get it tuned properly if you want it to last
im with del sol up there get it tunned that shit is hella important if u want a reliable car u can play with
specs:
stock internal
450cc injector
jdm intercooler
any info thanks
with AFC , you are pushing killer->6psi , get your ECU Chipped first and tune it correctly !
check out ZealAutowerks - Honda Compression Calculatorfind out what your effective CR is and make sure its a green signal. Too much boost will cause detonation, and thats not good for d stock internals. Unless you wanna spend loads of money rebuilding a car thats not meant for giving tonnes of horse power. The rod-stroke ratio isnt very boost friendly. If you just wanna boost with stock internals, expecting 160whp or something just go for 6 psi boost and tune it.
just my 2 cents
specs:
stock internal
450cc injector
jdm intercooler
any info thanks
unchipped ecu? interesting...probably should get it chip and get it tune....max psi is depending on the tune and motor condition...
