o2 censor
JDMB20Coupe
Powerd With 1 Cam
ive got a D15B in my 95 civic and i just got a header from a Y8 motor so it doesnt have the o2 censor whole is i run it without the o2 censor will it mess anything up?
im not really sure what your getting at. so where is the problem?
I typically only see censors late at night on girls gone wild commercials...
If you are thinking about running without an o2 sensor, then you could, but I wouldn't advise it. It would run really rich and you would get piss for gas mileage.
And if you have the dp for your motor, then why not just install that too?
ive never in my life saw a honda header that didnt have a bung in it somewhere, but if not just go to the muffler shop and have them put one in there for you
If you put the header on now, you'll have to take it off to weld the bung and put it back on again after they weld the bung.
oh ok thankyou its supposed to have it but its a Y8 header and z6 down pipe. and with those pieces the bung is on the other peice
even a y8 header should have it, it would have one on the header and one on the down pipe
honestly man I would pick up a cheap eBay header, they look a hell of alot nicer and are more efficient
:werd:
A stainless steel Megan Racing header is less then $150 shipped to your door. That's the route I would go...
My Megan bolts right up to my CRX and the Cat back. Really nice fit if you ask me. Unfortunately it has a little kink in it from the wrecked car I pulled it off of. Can't seem to get it out.
o2 bungs are like $5 bucks though + getting it welded
