Another expert expressed concern about the amount of energy it would take to generate the required air pressure: 4,500 pounds per square inch, or more than 120 times the pressure inside the tires of a typical four-door sedan.
"That is above what you normally find even in an industrial setting," said William Bulpitt, senior research engineer at the Georgia Institute of Technology's Strategic Energy Institute.
