crx needs engine
josh29
I need to know what engines will fit in my 1986 honda crx.
K24.
B20/VTEC
B18C5
B16B
B16A
meh.
I have a d16a6 block out of a 91' Si, will that fit? you can put a V-TEC d16y8 head on it!.
Yea, it will work but, Your gonna probbly be stuck where im at right now if your crx isn't Si, you'll have to do a dpfi to mpfi unless you know more about this than me then you'll be stuck for a while.
He has a 86; it's not drop in, The D16A1 would probably the best easy swap for your car. The 88-00 D-series require more work(mounts, axles, linkage, wiring).
Hasport has the mounts to get a B-series in it, wiring would be the hardest part, and if it started life carbureted, for get about swapping it, as you have to change all the carbed fuel lines, gas tank, for the fuel injection parts, and do some major major electrical work.
