hi i got a 91 da ls with a jdm b16a. converted the obd1 b16 to obd0 and repinned the dizzy to obd0 to drop in the da then ran a obd0-obd1 ecu jumper harness. the car does not want to start the codes the ecu is putting out is (4-crank angle sensor or cercuit,ecu...20-electrical load detector or cercuit). so heres the problem im pretty sure now that im running the obd1ecu the car is pretty much obd1 does obd1 have a crank angle sensor,and what is the electrical load detector or curcuit, and how do u fix it any input would be apprecieted thanks.
