DA with B20vtec
FiftyFive
I am looking into purchasing a car. The car has a B20b/b16 motor. I was wondering what you guys thought of this setup. Done right?
BLOCK
B20B block 84mm
RS machine 84mm pistons (11.5:1)
stock PR4 rods (resized) with ARP rod bolts
Stock sleeves
PR4 crank (micropolished)
Top line bearings
oem head gasket
ITR oil pump
ITR water pump
passwordjdm magnetic drain plug
oem oil filter
all new OEM gaskets
HEAD
PR3 B16 head (resurfaced)
new valve seals
3 angle valve job
intake & exhaust ports have been cleaned up
Rocket motorsports valve springs and Ti retainers
Skunk2 pro series Pro1+ cams
BOLT-ONS
AEBS intake manifold
obd1 gsr throttle body 65mm bored out by maxbore.com
DC intake arm with blox velocity stack with blox filter
hondata intake manifold gasket
Hy-tech replica race header
k-teller 2.5" SS piping, no cat or resonators
2.5' SS magnaflow oval muffler
STR fuel rail with braided fuel line feed
B&M fuel regualtor and guage on top of rail
Walbro 255 fuel pump
full-race ls/vtec oil line kit
Allstar breather catch can
new oem ITR ignition wires
NGK plugs
new oem cap and rotor
STR cam gears
King motorsports extended intake & exhuast studs
Fluidyne radiator
Samco hoses (red)
slim line fan
Mugen fan switch
Mugen thermostat
new oem fuel filter
Innovative race billet mounts
new oem clutch line
new oem speedometer cable
new oem ITR valve cover with ITR crome oil cap
Odyssey PC680 battery with odyssey battery box holder
Thanks for the advice guys. It means a lot.
sounds like a well built motor,the only thing im unsure of is the bearings,
but things you should ask the seller,who built the motor,who di the machine work,ask him if he has receipts,
how much are you trying to spend on this car and hows the body?
The body is mint, fresh paint including jambs. Spoon wheels, very extensive suspension setup. hes asking 5500, its a 90. Very jdm.
sounds like a nice car,,but it is a DA cars damn near 20 years old
to me i would buy it if i wanted it,but other people will say thats too much
injen, change Good to Reliable in your sig. Makes more sense.:cool:
No one in their right mind would say $5,500 is too much for a well built car like this one. Even if the car is 18 years old. Hell, i'd wonder why he's selling it so cheap...
Clean. If you like it, swoop it up. I don't like my cars pretty much finished so I wouldn't buy it for myself.
It makes more sense that way because that's how the saying actually goes lol...
I honestly dont have time to build another car. I've had a lot of hondas and just got rid of an Evo. DAs were always my favorite. Might have to go get this. I thought the price was amazing too. The suspension wheels and motor is well over 5500. I just wanted to know what you guys thought about the build. Im not too familiar with b20vtecs.
id buy it if i was you!.... wish i could have found a DA with a clean ass b20vtec swap like that. i settled for a DC2 b20vtec that was a not quite as close to a finished project. but its clean and it was cheaper :D
