makewheelies304
anyone have a good how to on puttin a b18a1 in a ef?
axles=90-93 integra axles with intermediate shaft,
do you wanna stay obd0???or do you wanna convert to obd1??
Nice find.ok i had a 90 civic hb 3 years ago and i swapped a zc in it..i sold that...well now i bought a 91 civic hb std. for 500 bucks...with not a spot of rust!!
Ok, at least you've done some research.i just bought a b18a1 and i ordered mounts and the shift linkage.. and i also have the si knuckles.
You can use a hydro, but youll need the hydro to cable adapter from Hasport.but what i really need is a cable tranny!!!!
PR4, (comes in OBD0 and OBDI) I would do an OBD conversion and run OBDI, there are better tuning programs for OBDI. Many people use Crome because its free and many shops are familiar with it. Do a lot of research about proper tuning, and youll be glad you did.what ecu will i need? ( the car is getting turboed, so idk if that matters or not?)
DA Integra.what axels will i need?
Other than pounding a dent in the drivers side frame rail for alternator clearance.will i have to do any fabricating to make it fit?
and bending the lip down on the rear crossmember for the tranny bracket
is the car an si?!?!
im not familiar with std's
