Turbo off of a disel pickup
zootel
I have bought a turbo off of a turbo disel pick up to try and see if i can get it to work on my crx. any suggestions would help.
Same reason why all other turbo cars make that noise....
My only thought is the turbo lag from a turbo that large on a small engine would be atrocious.
That's true; most of the people using diesel(semi's) turbos have it on their V8's.
Some diesel turbos aren't that big; I work at Caterpillar and the Front wheel loaders have a moderate sized turbo(probably about the size of a T25). Then again, construction tractors don't have to move as fast as semi's or move as much weight.
i say try it out and see how it performs.
never know, diesel turbo may be the best new performance swap.
"PUT THAT ON YOUR B20 AND SUCK ON IT!"
I've seen that pic before. I just don't know of a car on the road that would spool that beast.
Don't crx's come with the b16?
Wow.... Makes me want a CRX :cool:
That engine is actually the first thing that came to mind when i saw that turbo.
Maybe i should pick up one, friend has alot of dying turbo diesel trucks at the Rent-All centre...and yes we spell it centre not center.
what truck did the turbo come off of?
are there any disel cars that come with turbos?
I don't know much of turbos, but diesels make all their power at low rpm, we're talking 2500-3500 rpm.. I would think that a turbo designed to give boost at such low rpm might go nuts in a high strung gas engine.. Entirely a guess, though.
P.S. Is that a train turbo or something?
This is off of like a ford turbo disel pickup not a semi. and I bought it for 35 bucks. used in good shape.... the guy got it from an estate auction and it was in a box that he bought for like 5 bucks. you can go to the link at the bottom to see pics of it. I am also building my own manifold for it out of my stock one im gonna just take some flat steel plate and cut it to mount up to the turbo and one to mount to the manifold then weld pipe to both to make a custom turbo manifold. i plan to run all of my exuast through the turbo (it should spool nicely that way i hope). I figured that it would be better then like the manifolds i have seen that only allow partial of the exuast through the turbo. the turbo is a Schwitzer S1 Turbo Charger by Borg Warner.
eBay Motors: USED Schwitzer S1 Turbo Charger Borg Warner (item 380054335984 end time Aug-13-08 19:26:57 PDT)
