Dumb Question
Codie94
How would I put my window back into track because everytime i roll it up i have to ull back on the window to make it fit....I cant figure it out i keep trying to fix it but its just not working for me. Man Window
You have to take off the inside door panel. There are 2 bolts on the bottoms of the tracks that can be loosened and adjusted. You may need a new rubber track too? I did...
But that's what I know for powered windows. If you've got manual windows, idk I havn't ever done those.
theres no dumb question on haondswap.com ....lol
Manual windows are the same, two 12mm bolts at each end of the glass.;)
SO whats the difference between it and a USDM sheild?
Haha, I died laughing when I read it because it's all too true lol.
Is your window problem on the 94 civic? Is it manual or electric? Is it a 2 or 4 door? I have noticed on the 2 door especially that when the door gets slammed alot that the window either comes off the tracks or the tracks get bent/twisted over time. What I have done is taken out the entire track system and bent it back. This is difficult but it has worked for me. I have also seen the rubber that goes inside the tracks get worn the wrong way and need to be replaced. Let me know. Good Luck.
